hi, everyone, for a formula with multiple reported formation energies,how to choose and download the most stable structure with the lowest formation energy?How to write a query statement ?
I’ll be very thankful for any suggestions
Since finding the entry with the lowest formation energy for a given formula involves an “aggregation” operation (see MongoDB aggregation) it is probably easiest to do this by sorting a list of entries you’ve already queried for a given formula.
In the Python example below, entries are obtained from the Materials Project using MPRester
, then we use sorted()
to sort by energy per atom and take the first element of the sorted list. Note that we can use the energy_per_atom
property instead of the actual formation energy since we’re dealing with entries all of the same chemical formula.
from pymatgen.ext.matproj import MPRester
formula = "" # FILL IN desired formula between quotes
with MPRester() as mpr:
entries = mpr.get_entries(formula)
min_entry = sorted(entries, key=lambda e: e.energy_per_atom)[0]
