How to combine ZBL and eam/alloy potentials for different atom types?
This is the first time I want to use multiple interatomic potentials. I want to simulate oxygen irradiation into iron. I have a file for the Fe-Fe interactions (this is how I used it):
pair_style eam/alloy
pair_coeff * * fe_mendelev_eam_alloy.potential Fe
In my current problem, O-O will never happen and I believe that O-Fe can be simply simulated with a ZBL potential. The O ion is very energetic and the Fe sample is really thin. How can I combine these two interactions? I tried:
pair_style hybrid eam/alloy zbl
pair_coeff 1 1 eam/alloy fe_mendelev_eam_alloy.potential Fe
pair_coeff 1 2 zbl 2.0
And I get:
ERROR: Illegal pair_style command (src/pair_zbl.cpp:184)
Last command: pair_style hybrid eam/alloy zbl
Hi @acgc99 ,
Please refer to the zbl pair style documentation. It requires inner switching distance and outer cutoff radii when it is declared. This is where this error stems from.
Thanks for your response. This is the modified code:
pair_style hybrid eam/alloy zbl 3.0 4.0
pair_coeff * * eam/alloy C:\Users\acgc99\Local\Sync1\Estudios\UA\PhD\Codes\InteratomicPotentials\Fe\fe_mendelev_eam_alloy.potential Fe NULL
pair_coeff 1 2 zbl 2.0 3.0
I’m just putting random values for the arguments. Which arguments are being applied? I mean 3.0 4.0 or 2.0 3.0? Isn’t this redundant?
This code also produces an error: ERROR: All pair coeffs are not set (src/pair.cpp:253). If I add pair_coeff 2 2 zbl 2.0 3.0, then I get ERROR: Incorrect args for pair coefficients (src/pair_zbl.cpp:221) for that line. For my particular problem, there’s only going to be a single O atom per simulation.
This depends on your model. The argument provided in the pair_style and pair_coeff commands are not the same. Please, read the manual.
Please consider (re-?)reading the guidelines of the forum. They provide steps to debug these issues on your side before submitting a simplified version of your problem to get more insightful comments.
The following minimal working example runs on my computer without producing an error:
lattice sc 1.
region mybox block 0 1 0 1 0 1
create_box 2 mybox
pair_style hybrid eam/alloy zbl 3. 4.
pair_coeff * * eam/alloy AlO.eam.alloy Al NULL
pair_coeff 1 2 zbl 12. -8. #  Dummy values
pair_coeff 2 2 zbl -8. -8. # Dummy values
This was done using the version of 19 nov 2024 (I didn’t recompile a more recent version on this machine). From my perspective, the error stems from some writing of the commands and thus requires a more deep understanding of the manuals’ instruction on how to format your input file.
If you think there is still an issue from the parsing of the pair styles and a bug in the code, please provide more details on your version of the code and all the input files you are using.
