Hi all,
I am trying to find a way to create a temperature anisotropic system (say in 2 dimensions). All the particles in system are similar.
Is there anyway in lammps to thermostat x and y velocities separately?
Based on one earlier post I tried following. The input is working but Tx and Ty are not reaching to desired.
compute txx all temp/partial 1 0 0 #x temperature
compute tyy all temp/partial 0 1 0 #y temperature
equilibrate
velocity all create {Td} 5812775 temp new3d units box
fix eq1a all langevin {Td} {Td} {trx} 334299
fix eq1b all langevin {Tdn} {Tdn} ${trx} 56849
fix eq all nve
thermo 100
fix 4 all enforce2d
fix_modify eq1a temp txx #fix my_thermostat now only operates on the x component
fix_modify eq1b temp tyy #fix my_thermostat now only operates on the y component
Is there a better and/or correct way to achieve temperature anisotropy?
Sanat
