Dears,
I want to obtain a cross-linked polyethylene (XLPE) system. First, I constructed an amorphous system with 3 polyethylene chains of 10 carbon atoms, under PCFF forcefield. And then converted it into the data file using msi2lmp tool. Then I attempted to cross-link the chains in LAMMPS by fix bond/create command. However, the chains seem to not cross-link with each other as the cumulative number of the bonds created remains 0 all the time (see the variable v_N1 in the log file). What are the problems that prevent the carbon atoms to cross-link and how to solve them? Thank you very much!
Besides, I also want to ask, when I convert the 3-chain polyethylene model exported from the Materials Studio into the data file, why there are 3 atom types (2 carbon atom types and 1 hydrogen atom type) rather than 2 atom types (1 carbon atom type and 1 hydrogen atom type)? And the two carbon atom types seem to have the same attributes.
The following are the input file and part of the data file.
input file:
cross-link of polyethylene
units real
newton on off
atom_style full
neighbor 2.0 bin
neigh_modify delay 0 every 5 check yes
pair_style lj/class2/coul/long 10
bond_style class2
angle_style class2
dihedral_style class2
improper_style class2
kspace_style pppm 1e-4
read_data 3chainsPE.data
dump 1 all atom 1000 crosslink.lammpstrj
thermo 1000
velocity all create 300 428459 dist gaussian
timestep 1.0
fix 1 all npt temp 300.0 450.0 100.0 iso 1.0 150.0 1000.0
fix 2 all bond/create 1 1 3 1 2 prob 1 1423 # C3-C2
fix 3 all bond/create 1 1 1 1 4 prob 1 1423 # C3-C3
fix 4 all bond/create 1 3 3 1 4 prob 1 1423 # C2-C2
variable N1 equal f_2[2]+f_3[2]+f_4[2]
thermo_style custom step temp press etotal ebond epair v_N1
run 50000
write_data XLPE.data
part of the data file:
LAMMPS data file. msi2lmp v3.9.9 / 05 Nov 2018 / CGCMM for 3chainsPE
there are three pe chains in the amorphous system, with each chain having 10 carbon # atoms. 1-C3, 3-C2, 2-H
96 atoms
93 bonds
180 angles
243 dihedrals
120 impropers
3 atom types
4 bond types
7 angle types
7 dihedral types
6 improper types
0.696054580 9.856854580 xlo xhi
1.817578638 10.978378638 ylo yhi
-0.485494923 8.675305077 zlo zhi
Masses
1 12.011150 # c3
2 1.007970 # hc
3 12.011150 # c2
Pair Coeffs # lj/class2/coul/long
1 0.0540000000 4.0100000000 # c3
2 0.0200000000 2.9950000000 # hc
3 0.0540000000 4.0100000000 # c2
Bond Coeffs # class2
1 1.1010 345.0000 -691.8900 844.6000 # c3-hc
2 1.5300 299.6700 -501.7700 679.8100 # c3-c2
3 1.1010 345.0000 -691.8900 844.6000 # hc-c2
4 1.5300 299.6700 -501.7700 679.8100 # c2-c2
Angle Coeffs # class2
1 107.6600 39.6410 -12.9210 -2.4318 # hc-c3-hc
2 110.7700 41.4530 -10.6040 5.1290 # hc-c3-c2
3 107.6600 39.6410 -12.9210 -2.4318 # hc-c2-hc
4 110.7700 41.4530 -10.6040 5.1290 # c3-c2-hc
5 110.7700 41.4530 -10.6040 5.1290 # hc-c2-c2
6 112.6700 39.5160 -7.4430 -9.5583 # c3-c2-c2
7 112.6700 39.5160 -7.4430 -9.5583 # c2-c2-c2
Dihedral Coeffs # class2
1 -0.1432 0.0000 0.0617 0.0000 -0.1083 0.0000# hc-c3-c2-hc
2 0.0000 0.0000 0.0316 0.0000 -0.1681 0.0000# hc-c3-c2-c2
3 -0.1432 0.0000 0.0617 0.0000 -0.1083 0.0000# hc-c2-c2-hc
4 0.0000 0.0000 0.0316 0.0000 -0.1681 0.0000# hc-c2-c2-c2
5 0.0000 0.0000 0.0316 0.0000 -0.1681 0.0000# c3-c2-c2-hc
6 0.0000 0.0000 0.0514 0.0000 -0.1430 0.0000# c3-c2-c2-c2
7 0.0000 0.0000 0.0514 0.0000 -0.1430 0.0000# c2-c2-c2-c2
Improper Coeffs # class2
1 0.0000 0.0000
2 0.0000 0.0000
3 0.0000 0.0000
4 0.0000 0.0000
5 0.0000 0.0000
6 0.0000 0.0000
BondBond Coeffs
1 5.3316 1.1010 1.1010
2 3.3872 1.1010 1.5300
3 5.3316 1.1010 1.1010
4 3.3872 1.5300 1.1010
5 3.3872 1.1010 1.5300
6 0.0000 1.5300 1.5300
7 0.0000 1.5300 1.5300
BondAngle Coeffs
1 18.1030 18.1030 1.1010 1.1010
2 11.4210 20.7540 1.1010 1.5300
3 18.1030 18.1030 1.1010 1.1010
4 20.7540 11.4210 1.5300 1.1010
5 11.4210 20.7540 1.1010 1.5300
6 8.0160 8.0160 1.5300 1.5300
7 8.0160 8.0160 1.5300 1.5300
AngleAngle Coeffs
1 -0.3157 -0.3157 -0.3157 107.6600 107.6600 107.6600
2 0.2738 0.2738 -0.4825 107.6600 110.7700 110.7700
3 0.2738 -0.4825 0.2738 110.7700 107.6600 110.7700
4 0.2738 0.2738 -0.4825 107.6600 110.7700 110.7700
5 0.1184 -1.3199 -1.3199 110.7700 110.7700 112.6700
6 -1.3199 0.1184 -1.3199 110.7700 112.6700 110.7700
AngleAngleTorsion Coeffs
1 -12.5640 110.7700 110.7700
2 -16.1640 110.7700 112.6700
3 -12.5640 110.7700 110.7700
4 -16.1640 110.7700 112.6700
5 -16.1640 112.6700 110.7700
6 -22.0450 112.6700 112.6700
7 -22.0450 112.6700 112.6700
EndBondTorsion Coeffs
1 0.2130 0.3120 0.0777 0.2130 0.3120 0.0777 1.1010 1.1010
2 0.0814 0.0591 0.2219 0.2486 0.2422 -0.0925 1.1010 1.5300
3 0.2130 0.3120 0.0777 0.2130 0.3120 0.0777 1.1010 1.1010
4 0.0814 0.0591 0.2219 0.2486 0.2422 -0.0925 1.1010 1.5300
5 0.2486 0.2422 -0.0925 0.0814 0.0591 0.2219 1.5300 1.1010
6 -0.0732 0.0000 0.0000 -0.0732 0.0000 0.0000 1.5300 1.5300
7 -0.0732 0.0000 0.0000 -0.0732 0.0000 0.0000 1.5300 1.5300
MiddleBondTorsion Coeffs
1 -14.2610 -0.5322 -0.4864 1.5300
2 -14.8790 -3.6581 -0.3138 1.5300
3 -14.2610 -0.5322 -0.4864 1.5300
4 -14.8790 -3.6581 -0.3138 1.5300
5 -14.8790 -3.6581 -0.3138 1.5300
6 -17.7870 -7.1877 0.0000 1.5300
7 -17.7870 -7.1877 0.0000 1.5300
BondBond13 Coeffs
1 0.0000 1.1010 1.1010
2 0.0000 1.1010 1.5300
3 0.0000 1.1010 1.1010
4 0.0000 1.1010 1.5300
5 0.0000 1.5300 1.1010
AngleTorsion Coeffs
1 -0.8085 0.5569 -0.2466 -0.8085 0.5569 -0.2466 110.7700 110.7700
2 0.3113 0.4516 -0.1988 -0.2454 0.0000 -0.1136 110.7700 112.6700
3 -0.8085 0.5569 -0.2466 -0.8085 0.5569 -0.2466 110.7700 110.7700
4 0.3113 0.4516 -0.1988 -0.2454 0.0000 -0.1136 110.7700 112.6700
5 -0.2454 0.0000 -0.1136 0.3113 0.4516 -0.1988 112.6700 110.7700
6 0.3886 -0.3139 0.1389 0.3886 -0.3139 0.1389 112.6700 112.6700
7 0.3886 -0.3139 0.1389 0.3886 -0.3139 0.1389 112.6700 112.6700
Atoms # full
1 1 1 -0.159000 6.604461002 3.586085686 5.364481687 0 1 0 # c3
2 1 2 0.053000 6.894786610 4.022718417 6.330580459 0 1 0 # hc
3 1 2 0.053000 7.314779609 3.950771599 4.612033539 0 1 0 # hc
4 1 2 0.053000 5.606022917 3.969091269 5.104165507 0 1 0 # hc
5 2 3 -0.106000 6.608589871 2.061913304 5.418187323 0 1 0 # c2
6 2 2 0.053000 6.456460023 10.831237834 4.398340784 0 0 0 # hc
7 2 2 0.053000 5.745224134 10.879364391 6.009828321 0 0 0 # hc
8 3 3 -0.106000 7.903265530 10.647792740 6.005024093 0 0 0 # c2
9 3 2 0.053000 8.048862342 1.863693803 7.033479610 0 1 0 # hc
10 3 2 0.053000 8.760883737 1.871024730 5.428396743 0 1 0 # hc
