I am trying to build LAMMPS with USER_PLUMED using make in the src folder. However, while doing a make mpi
I run into the following error :
mpicxx -g -O3 -DLAMMPS_GZIP -DLAMMPS_MEMALIGN=64 -I../../lib/nnp/include -I../../lib/plumed/includelink -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX=1 -D__PLUMED_WRAPPER_CXX=1 -c ../min.cpp In file included from ../pointers.h:24:0, from ../min.h:17, from ../min.cpp:22: ../lmptype.h:34:4: error: #error LAMMPS is planning to transition to C++11. To disable this error please use a C++11 compliant compiler, enable C++11 (or later) compliance, or define LAMMPS_CXX98 in your makefile #error LAMMPS is planning to transition to C++11. To disable this error please us ^ Makefile:104: recipe for target 'min.o' failed make[1]: *** [min.o] Error 1
However, my gcc version is 5.4.0 which is compliant with C++14 as well. What needs to be defined in the Makefile exactly? Is there any documentation for this ( specifically with make and not cmake)
I did the following before this:
