Dear Materials Project Team,
Greetings!
I want to query some questions about dos:
1、As shown in the following code, does the presence of “orb_dos.densities[Spin.down]” mean that Spin polarization is turned on? If “orb_dos.densities[Spin.down]” is None, does Spin polarization not turn on?
2、If Spin polarization is not turned on, the total dos of an orbit is “orb_dos.densities[spin.up]”, right?
3、If spin polarization is turned on, if I want to get the total dos of an orbital, I need to add the absolute value of orb_dos.densities[spin.up] to the absolute value of orb_dos.densities[spin.down], right?
For example, for the d orbital, it’s absolute value of d_spin_up plus absolute value of d_spin_down, right?
4、Is there a more convenient way to get the total dos of s,p,d and f orbitals?
from pymatgen.electronic_structure.core import Spin
import matplotlib.pyplot as plt
with MPRester("XXX") as mpr:
dos = mpr.get_dos_by_material_id("mp-XXX")
energies = dos.energies
fermi_level = dos.efermi
total_dos_up = dos.densities[Spin.up]
total_dos_down = dos.densities.get(Spin.down, None)
energies_fermi = energies - fermi_level
spd_dos = dos.get_spd_dos()
s_spin_up = None
s_spin_down = None
p_spin_up = None
p_spin_down = None
d_spin_up = None
d_spin_down = None
f_spin_up = None
f_spin_down = None
for orb, orb_dos in spd_dos.items():
if orb.name == 's' and Spin.up in orb_dos.densities:
s_spin_up = orb_dos.densities[Spin.up]
if orb.name == 's' and Spin.down in orb_dos.densities:
s_spin_down = orb_dos.densities[Spin.down]
if orb.name == 'p' and Spin.up in orb_dos.densities:
p_spin_up = orb_dos.densities[Spin.up]
if orb.name == 'p' and Spin.down in orb_dos.densities:
p_spin_down = orb_dos.densities[Spin.down]
if orb.name == 'd' and Spin.up in orb_dos.densities:
d_spin_up = orb_dos.densities[Spin.up]
if orb.name == 'd' and Spin.down in orb_dos.densities:
d_spin_down = orb_dos.densities[Spin.down]
if orb.name == 'f' and Spin.up in orb_dos.densities:
f_spin_up = orb_dos.densities[Spin.up]
if orb.name == 'f' and Spin.down in orb_dos.densities:
f_spin_down = orb_dos.densities[Spin.down]
Looking forward to your reply, thank you very much.
