How to download the total dos?
I often use get_dos_by_material_id to get Dos information.
But I don’t know how to get total dos.
If I do this,
from pymatgen import MPRester
key = MPRester("my_API_key")
data = key.get_dos_by_material_id('mp-635471')
print(data)
Complete DOS for Full Formula (Ni3 Pt1)
 Reduced Formula: Ni3Pt
 abc   :   3.648502   3.648502   3.648502
 angles:  90.000000  90.000000  90.000000
 Sites (4)
   #  SP      a    b    c
   0  Ni    0.5  0    0.5
   1  Ni    0    0.5  0.5
   2  Ni    0.5  0.5  0
   3  Pt    0    0    0
But I want to get the value of the energy and the density of states about total dos.
I already have checked the type of “data”.
That is <class ‘pymatgen.electronic_structure.dos.CompleteDos’>.
I can’t find the def. to get the total dos value at that class.
Is there any method to get the total dos directly from pymatgen?
Hello Fred,
A solution is to do:
m = MPRester(‘api_key’)
dos = m.get_dos_by_material_id(‘mp_id’)
total_dos = sum(dos.densities.values())
This will also sum both spins if present.
I hope this helps!
Howard Yanxon
