SlabGenerator can generate Slabs from bulk Structures. However, if I have some ready-made slab structure files, such as the files for 2D materials, how can I get corresponding Slab objects from the files?
this is pretty easy, if you have a pymatgen Structure object already which is also easy to get from a file. At minimum you have to give a miller index for a Slab to initialize from a Structure, but you could specify more, e.g. a correct oriented unit cell and possible a nonzero shift. It really depends what you want your Slab object for.
A simple function that I used before is this:
from pymatgen.core.surface import Slab
def slab_from_structure(miller, structure):
"""Returns a pymatgen.core.surface.Slab from a pymatgen structure.
Parameters
miller : list of int
Miller indices given as a list of integers
structure : pymatgen.core.structure.Structure
Structure to be converted into a Slab
Returns
The input structure converted to a Slab
return Slab(lattice=structure.lattice,
species=structure.species_and_occu,
coords=structure.frac_coords,
miller_index=miller,
oriented_unit_cell=structure,
shift=0,
scale_factor=np.eye(3, dtype=np.int),
site_properties=structure.site_properties)
Many thanks. Once I find the most proper way to confirm the surface miller index, I will use your function.
