Would anyone please tell me how to use Fortran code to generate the structure file in the gzipped format for the ‘read_data’ command in LAMMPS simulation?
I mean what is the format of this gzipped file? Is it just a simple binary file or something else?
At the risk of possibly giving a retarded answer to a question I might not be understanding correctly, I would say that a “gzipped” file is just a file a .gz file that you obtained by doing the gzip command in linux. From quickly checking the manual, the gzipped file should come from a usual text file, no? So you can just build the structure in a text file as usual and do the gzip command on it. Why do you want a fortran code to do it?
