Dear Sir
I am trying to generate VASP input files by using pymatgen.
The following are the input python lines:
from pymatgen.ext.matproj import MPRester
from pymatgen.io.vasp.sets import MPRelaxSet
MP = MPRester("******")
a = MP.get_structure_by_material_id(“mp-19305”)
b = MPRelaxSet(a)
b.write_input(".")
After running, the error comes out: “ValueError: No POTCAR for Ca_sv with functional PBE found.”
Before that, I have run the lines firstly:
pmg config -p E:\POT_GGA_PAW_PBE E:\xxxx
However, the following errors come out: “An error has occured. Message is [WinError 2] The system cannot find the file specified. Trying to continue…”
The structure of E:\POT_GGA_PAW_PBE directory is as following:
- POT_GGA_PAW_PBE
|- Ac
||-POTCAR
and then I run
pmg config --add PMG_VASP_PSP_DIR E:\xxxx
The structure of E:\xxxx is as following:
- xxxx
|- POT_GGA_PAW_PBE
||- POTCAR.Ac
||- POTCAR.Ag
As have been shown in the example of pymatgen, the structure of resources directory should be
- psp_resources
|- POT_GGA_PAW_PBE
||- POTCAR.Ac_s.gz
||- POTCAR.Ac.gz
||- POTCAR.Ag.gz
|- POT_GGA_PAW_PW91
which are different from mine above, could anyone help me, Thank you very much!
