How can we get bond angles and bond length distribution in lammps. Is there any processing tool for getting distribution of bond angles and lengths all over the sheet.
that is best done with a custom post processing tool. you can take the
bond and angle definitions from a data file and then compute them and
histogram them. should be straightforward with a little bit of python
scripting.
if you are more into Tcl, you can use VMD which can read and parse
data files via the topotools plugin and can do time series of bond
lengths and angles via the label command or can use the measure
command for bonds and angles.
of course, that requires some script programming, too, but that is the
normal way of computational research...
Thank you axel, In my experiment of tensile test, I want to know how the angles and bond lengths are distributed over a system of atoms at particular time intervals. So, I shouldn’t use data file for angle and bond length distributions.
I want to load xyz dump files of particular time intervals into vmd and check the distribution (some bonds will be stretched) of angles and bond lengths.
But, I’m using graphene sheet with airebo potential by creating data file without bonds
time intervals. So, I shouldn't use data file for angle and bond length
distributions.
lengths.
But, I'm using graphene sheet with airebo potential by creating data file
without bonds
Is custom a separate post processing tool ?
not unless you write one yourself. it should be simple enough for a
simple system like yours.
i don't think that that will work for a setup like yours, where you
don't have a bond or angle style defined. you would have to create a
special topology for that and post-process with the rerun command.
if you had spent the time programming instead of asking, you might
have a usable code already...
