How to get band stuctures by mp-api
I am trying to retrieve band structures using the official example code from the documentation:
from emmet.core.electronic_structure import BSPathType
with MPRester(API_KEY) as mpr:
    bs_sc = mpr.get_bandstructure_by_material_id("mp-149")
However, this currently fails in my environment with a Pydantic ValidationError related to missing equivalent_labels fields:
ValidationError: bandstructure.setyawan_curtarolo.equivalent_labels
Field required
I then tried using use_document_model=False and retrieving the band structure via task_id, but get_bandstructure_from_task_id() attempts to access an old S3 path such as:
s3://materialsproject-parsed/bandstructures/1057384.json.gz
and returns:
MPRestError: No object found
My environment is:
mp-api version: 0.46.1
Python: 3.11
Could you please let me know what the currently recommended code is for retrieving a full pymatgen BandStructureSymmLine object for a material such as mp-149 or SiO2? Is the official example outdated, or is there a specific version of mp-api / emmet-core that should be used?
Hi Kchokawa,
Could you try using the latest version of mp-api==0.46.4 and emmet-core==0.87.1? With these versions, I’m able to run the script locally and retrieve the data successfully.
I am facing the same problem. if someone has any kind of solution, please let me know too
@Urooj_Fatima I just made a fresh conda environment with mp-api==0.46.4, emmet-core==0.87.1, pymatgen-core==2026.5.18, and pymatgen==2026.5.4, and this snippet works:
with MPRester("your_api_key_here") as mpr:
    ebs = mpr.get_bandstructure_by_material_id("mp-149")
If you have anaconda, conda, or miniforge, just run:
conda create -n mp python==3.13 --yes && conda activate mp && pip install mp-api==0.46.4
Thank you for your replys.
I updated the environment to use mp-api==0.46.4 and emmet-core==0.87.1, and the original issue was resolved.
I also noticed another small issue when trying to run the example code from the documentation:
    # -- line-mode, Setyawan-Curtarolo (default):
    # -- line-mode, Hinuma et al.:
    bs_hin = mpr.get_bandstructure_by_material_id("mp-149", path_type=BSPathType.hinuma)
    # -- line-mode, Latimer-Munro:
    bs_lm = mpr.get_bandstructure_by_material_id("mp-149", path_type=BSPathType.latimer_munro)
    # -- uniform:
    bs_uniform = mpr.get_bandstructure_by_material_id("mp-149", line_mode=False)
This gives the following import error:
ImportError: cannot import name 'BSPathType' from 'emmet.core.electronic_structure'
I was able to resolve this by changing the import to:
from emmet.core.band_theory import BSPathType
Hi @kchokawa,
Thank you for pointing that out! We’ve updated our documentation accordingly.
We’ve recently refactored and made some changes to our stack. You’re right that
is the correct import.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
