Alternately, why not add a test charge (or dipole) of unit magnitude
and measure how the potential energy changes in response?
You can do this using the "rerun" command.
Details below:
---- For the electrostatic potential ----
Suppose you have a system with "n" atoms.
Suppose you wish to calculate the eletrostatic potential at N
locations in space during your simulation.
Create a LAMMPS DATA file which has N+n atoms.
N of these "atoms" could be located at the positions you want to
calculate the electrostatic potential.
These N particles would be test/ghost particles which do not interact
with the system during the simulation. (You could give them zero
charge and zero Lennard-Jones epsilon parameters. To immobilize these
particles, you could either set their initial velocities to zero, or
simply exclude them from the group of atoms which are passed to the
"fix nvt" command, for example.)
After running the simulation, you can turn on the charge of one of the
ghost particles. (Assign it's charge to 1.0 in the "Atoms" section of
the DATA file.)
Then recalculate the potential energy of the entire system using the
"rerun" command.
http://lammps.sandia.gov/doc/rerun.html
The difference between the energies (at every frame in the trajectory)
is the electrostatic potential. You could repeat this process for
each of the N ghost particles you added to the simulation (each time
setting one of the charges to 1.0).
---- For the electric-field ----
You could do the equivalent thing using a "test dipole":
0) place an electric point dipole at the location(s) where you want to
query the electric field, but set their dipole moments to 0.
Run the simulation.
1) align the unit dipole along the x axis, calculate the energy using "rerun"
2) align the unit dipole along the y axis, calculate the energy using "rerun"
3) align the unit dipole along the z axis, calculate the energy using "rerun"
Subtract 0) from 1) and 2), and 3).
The three energy differences should be proportional to the x,y,z
components of the electric field at that location. If you have N
"test dipoles" in your simulation, you can repeat steps 1),2),3) for
all N of these particles. Again, when you run the simulation during
step 0, you would turn off dipole moments so they don't interact with
the other particles in the simulation (and you would immobilize them).
This way, users can even move the locations in space where the
electric field is queried by allowing the ghost particles to move, or
by writing a script to modify the corresponding lines of the "dump"
file.
Cheers
Andrew
