Consider a cubic unit cell of size, say 5 Angstroms. I now need to build a unit cell of size 5.5 Angstroms, for which I use set_cell routine with scale_atoms=True. But I do not want the atoms to be scaled along the z direction. Is there a way to turn off scale_atoms along a particular direction?
Thank you.
If you mean that you want to expand the atoms only in the xy plane but fix the positions at z axis, you could try these two steps.
- First, use
atoms.set_cell([5.5, 5.5, 5.0], scale_atoms=True)to change the first two axes. - Second, create an empty cell with a 5.5 Angstroms z axis by
atoms = Atoms(cell=[5.5, 5.5, 5.5]). Then you can useappendmethod ofAtomsinstances to add atoms to the new createdAtomsinstance from the old one.
Example codes:
from ase import Atoms
# suppose A is your current structure
A.set_cell([5.5, 5.5, 5.0], scale_atoms=True)`
# B is the new one with a larger z axis
B = Atoms(cell=[5.5, 5.5, 5.5])
for atom in A:
B.append(atom)
One can also do A.cell[2, 2] = 5.5 after the set_cell() in the above example. That directly edits the cell vector coordinate without changing the positions, and it won’t be necessary to build a new atoms object.
