How to hide the defect mesh and particles when rendering image using ovito python module?
Could anyone tell me how to hide the defect mesh and particles before rendering the image, and only retain the dislocation lines?
# import ovito python modules
import os
from ovito.io import import_file
from ovito.vis import Viewport
from ovito.modifiers import SelectTypeModifier, DislocationAnalysisModifier
# specify input file path and root path
input_path = r"F:\GitHubRepos\MDSimulation\LAMMPS-Practices\shear_compress\adp_Apostol2011_small\shear_compress.adp_Apostol2011-4.in_20251127233525_1764258266527_348\AlCuLMC_deformation.lmp"
# input_path = r"F:\GitHubRepos\MDSimulation\LAMMPS-Practices\shear_compress\adp_Apostol2011_full\shear_compress.adp_Apostol2011-5\AlCuLMC_deformation.lmp"
root_path = os.path.dirname(input_path)
# specify the pipeline and add modifiers
pipeline = import_file(input_path)
pipeline.add_to_scene()
select_modifier = SelectTypeModifier(operate_on='particles',property='Particle Type',types={1, 4})
pipeline.modifiers.append(select_modifier)
dxa_modifier = DislocationAnalysisModifier(only_selected=True)
dxa_modifier.input_crystal_structure = DislocationAnalysisModifier.Lattice.FCC
pipeline.modifiers.append(dxa_modifier)
outpath = os.path.join(root_path, f"Dislocations_{10:02d}.png")
vp = Viewport(type=Viewport.Type.Ortho, camera_dir=(0.2,-1.,-0.2), fov=30.0)
vp.zoom_all()
vp.render_image(size=(1024,768), filename=outpath, background=(1,1,1), frame=10, crop=True)
As shown in the figure below, the image rendered by the above script contains defect meshes and particles, which affect the observation of the dislocation lines.
dxa_modifier.defect_vis.enabled = False
pipeline.compute().particles.vis.enabled = False
https://www.ovito.org/manual/python/introduction/rendering.html#visual-elements
These codes worked. Thank you very much for your valuable suggestions.
