I install LAMMPS in Windows and it doesn’t have /src directory.
How to input pair_.cpp and pair_.h into LAMMPS in Window?
Best
Best
I install LAMMPS in Windows and it doesn't have /src directory.
How to input pair_*.cpp and pair_*.h into LAMMPS in Window?
are you talking about the pre-compiled windows installer packages?
there is no point in including the source code, since the code is
already compiled.
if you want to build a custom windows binary, you will have to
download the source code and compile it yourself. mind you, that is
not exactly a trivial task to do. LAMMPS expects a unix-like
compilation and development environment.
