How to make dump file into an xyz output file
How can you make your dump file and xyz output file. My issue is my dump files aren’t showing up at all however xyz output files are and they happen to work in ovito. How do i do this?
Your statement makes no sense. If regular dump output files would not be created, don’t you think that there would be an outcry of LAMMPS users for LAMMPS not working as it should?
Also, if LAMMPS would not create the dump files, how can you convert them to .xyz format?
So, what you mean exactly by “not showing up”?
You can create .xyz format dump files directly using the xyz dump style. But note that the xyz format is lacking the information about the simulation cell geometry.
