I have two different files from my LAMMPS simulations:
File 1: Per-particle results (positions, diameters, etc.). (All particles are the same, and the pair style granular is used).
File 2: Pairwise interactions results, which I computed using compute pair/local command. It contains information including force components (Fx, Fy, Fz) between particles. (They are not force components per particle, but rather the forces acting between pairs of particles.)
I successfully loaded the first file into OVITO and then added the second one using Load Trajectory, and now OVITO displays particles and shows pairwise interactions as bonds.
My question is:
How can I map and visualize the force components (Fx, Fy, Fz) between particles in OVITO?
Any suggestions or a brief walkthrough would be much appreciated.
