Hi all!
In workflow, for example double relax, how to customize the name for different structure files into the mongodb “name”?
When I use only jobs, I can easily change it to the specified name “test11111”, as shown in the red box.
However, when I use workflow like double relax, I specify the name as test however it doesn’t take effect in mongdb’s outputs, as shown in the blue box.
Hi @luogx37, you can call .append_name on any jobflow maker/job/flow (optionally with prepend=True to put any additions at the start of the name) which will recursively update all names in a flow
Thank you! It’s works well!!!
