I am using write_data command after minimizing the emergy of my system, to output the after equilibrium data. This command gives me all the bond, angle data. How can I tell it to write only the atom positions (x,y,z) of one type of atoms?
I only need the position of my carbon atoms after equilibrium.
Thank you so much, but this also gives me the data in every 100 * timesteps. Is there any way to out put the last timestep data only to get just the last position of atoms in that moment that the system is relaxed?
(I know that I can increase the N=100 and delet some information in the data file, but wanted to know if there is more neat way to ask LAMMPS to print the last time step data)
my time step is 0.01 and I am running for 5000 times. I used "write_dump CNT custom cntrelx.* id type x y z " to output the cnt relaxed atom positions, and I am getting a file with the name : “cntrelx.100”. I am not sure where 100 comes from since I am not asking for repetetive outputs. I want to make sure that the data I am outputting is the relaxed data. Could you please explain this to me and tell me how to use the command properly?
I noticed 100 in “cntrelx.100” means data belongs to timestep 100,
when the time step is 0.01, timestep 100 is 100*0.01=1, does that mean this data belongs to the last timestep of last run?
Thank you, I noticed that 100 in “cntrelx.100” means data belongs to timestep 100,
My time step is 0.01, so timestep 100 is the total time 100*0.01=1, does that mean this data belongs to the last timestep of last run?
Can you post your exact commands from the input? It should be 5000 not 100 unless you used reset_timestep. It is the number of timesteps completed not simulation time in the file name for *
