I am using edpd, energy conserved dissipative particle dynamics method to simulate a CNT inside water. For the output, I am getting the positions in space and the temperature and the density related to that position using the following commands:
compute temp all edpd/temp/atom
compute ccT all chunk/atom bin/3d x 0.0 100 y 0.0 100 z 0.0 100
fix stat all ave/chunk 1 6 1000 ccT c_temp density/number norm sample file
tempeditcnt.profile
My question is how can I output the temperature of each position as time passes (in different time steps). Sorry if this is a trivial question, but I could not find a method to output the temperature in timesteps to be used in edpd method (beads have internal temperature as well)
The first few commands of my code is:
units lj
neigh_modify one 10000 delay 0 check yes
change neighbor list parameters to avoid dangerous builds
atom_style hybrid edpd full
bond_style harmonic
angle_style charmm
System definition
region edpd block -50 50 -50 30 -22 23 units box
read_data data.data
create_atoms 2 random 16000 276438 NULL
#grouping
group cnt type 1
group liquid type 2
mass 1 1
mass 2 12
set atom * edpd/temp 1.0
set atom * edpd/cv 1.0E5
pair_style edpd 1.58 9872598
bond_coeff 1 80.0 1.2
angle_coeff 1 300.0 107.0 50.0 3.0
pair_coeff * * 18.75 4.5 0.41 1.58 1.41E-5 2.0 1.58 &
power 10.54 -3.66 3.44 -4.10 &
kappa -0.44 -3.21 5.04 0.00
compute mythermo all temp
thermo 100
thermo_modify temp mythermo
thermo_modify flush yes
