Dear All,
I hope you are doing well.
I have DSPE molecules in my system and need to include multiple copies of them. To achieve this, I wrote a routine that generates multiple molecules, each stored in a separate file. In each file, the atom IDs, bond, and angle information are identical across all molecules, and they are positioned at different Z-offsets to ensure separation.
However, when I run my LAMMPS simulation:
- With a small offset (e.g., 1): The molecules initially stick together at equilibrium and then gradually separate.
- With a larger offset: I get the error “bond atom missing,” which suggests that the simulation is trying to form bonds between atoms from different molecules.
I suspect that since all molecules use the same atom types (e.g., type 2 and 3), and there are predefined bonds between these types (e.g., between atom type 2 & 3), LAMMPS may be mistakenly creating bonds between separate molecules. When the molecules move farther apart, these unintended bonds break, causing the error.
My Question:
How can I ensure that bonds only form within each individual molecule and not between different molecules?
- Changing atom IDs for each molecule would be complex and difficult to track.
- Would assigning molecule IDs be sufficient to prevent inter-molecular bonding while keeping atom IDs unchanged?
- What is the simplest and most efficient way to resolve this issue?
Thank you so much for your time and care,
Delaram
