Dear Lammps users,
I want to simulate a compression test. I have set a group of particles as the load. But it appears penetration between the simple particles and the load particles (Please the the pictures in the attachment). How can i prevent the particles from penetration?
Part of my script is as follows,
group aggregate type 1
group asphalt type 2
group base type 3
group load type 4
set group aggregate meso/rho {rhoaggregate} #set density of aggregate
set group asphalt meso/rho {rhoasphalt} #set density of asphalt
reset_timestep 0
pair_style hybrid/overlay sph/taitwater/morris lj/cut {sgmL} pair_coeff * * lj/cut {epsL} {sgmL} pair_coeff 1 1 lj/cut {epsS} {sgmS} pair_coeff 2 2 sph/taitwater/morris {rhoasphalt} {c} {mu} ${h}
bond_style harmonic
bond_coeff 1 {kB} {dB}
bond_coeff 2 {kA} {l}
fix 1 load addforce 0.0 {fmax} 0.0
fix 2 load setforce 0.0 NULL 0.0
fix 3 load rigid single
fix 4 aggregate meso
fix 5 asphalt meso
#fix 6 load meso
fix 7 base meso/stationary
fix 8 all viscous 1
fix 9 all gravity -9.81 vector 0 1 0
fix 10 load rigid single force 1 off on off torque 1 off off off
fix 11 aggregate bond/break 1 1 {dBmax}
fix 12 aggregate bond/break 1 2 ${lmax}
fix 13 all enforce2d
Many thanks and kind regards,
Pengbo Li
