I am trying to restart a SMD simulation which I perform a pull-out test of a protein.
In the initial SMD simulation, the tether point of the spring is far away from the SMD atoms which is named pulled.
The following is the command in the initial SMD simulation:
The output of the SMD vector is
Step Temp TotEng pull1[1] pull1[2] pull1[3] pull1[4] pull1[5] pull1[6] pull1[7]
1100000 299.85343 -576509.82 6.966186 0 0 6.966186 9492.9317 9493.6591 64.079979
I restart the simulation at the 1100000th step.
In order to get the same force at the 1100000th step, I use the command shown below in the restart input file,
However, the force is not equal to 6.966186 and becomes negative.
In the output file:
1100000 299.85343 -576509.82 -7.274 0 0 -7.274 9493.6284 9493.6591 64.079906
I think that problem is the value of R0 is not correct.
And also in LAMMPS manual, it mentions that LAMMPS store the information of SMD in restart file, and to re-enable it, the fix command in the new input script must use the same fix-ID and group-ID as was used in the input script that wrote the restart file.
But I have no idea how re-enable a SMD simulation in restart file.
Does anyone have some experience to restart a SMD simulation?
Or any idea why the force is not the same and even becomes negative?
protein.
pull1[7]
In the output file:
pull1[7]
no. your understanding or R0 is incorrect.
just use the exact same command. please read the fix smd documentation
about what R0 means. you almost certainly want it to be 0.0.
This simply means that you have to use a fix smd command
in the new simulation that is consistent with the fix
smd command you used in the 1st simulation.
