Hello, all.
How can i use NPAT ensemble with ase?
I usaully used
dyn = NPTBerendsen(atoms, timestep=0.1 * units.fs, temperature_K=300,
taut=100 * units.fs, pressure_au=1.01325 * units.bar,
taup=1000 * units.fs, compressibility_au=4.57e-5 / units.bar)
command to run NPT ensemble.
Now I want to run NPAT ensemble which fix y and z and only force pressure to x direction which is similar with lammps command ’ fix 1 all npt temp 300.0 300.0 100.0 x 1.0 1.0 100.0 ’
Could you give any advice for solving this probrem?
Any help would be appreciated.
Thank you
