I need to scrape all ABO3 using materials project api. I have used following code-
from pymatgen.ext.matproj import MPRester
api_key= “*********”
mpr= MPRester(api_key)
entries= mpr.query(‘**O3’, [“structure”, “material_id”, “pretty_formula”])
But in this process, an error occurred (type error). Now, how do I get all perovskite information using pymatgen?
Hi @Md_Abdullah_al-Rifat,
It looks like you’re using the legacy MP API. Please take a look at our new API and documentation, and let me know if you’re still running into issues.
brother… I have tried a lot… But couldn’t solve the code… Actually all the code showing in youtube or website get backdated I think… Can you please provide me a sample code where I can get materials properties for ABO3 (perovskite type) structured materials.
Hi @Md_Abdullah_al-Rifat, the documentation actually includes this particular example, but I’ll put it here along with some necessary filtering code to get only the ABO3 structures:
from math import gcd
with MPRester() as mpr:
all_docs = mpr.materials.summary.search(formula="ABC3",chemsys="O-*-*",fields=["structure","material_id","formula_pretty"])
perovskite_docs = []
for doc in all_docs:
composition = doc.structure.composition.remove_charges().as_dict()
multiplicity_gcd = gcd(*[int(v) for v in composition.values()])
composition_reduced = {k: v/multiplicity_gcd for k, v in composition.items()}
other_elements = [k for k in composition if k != "O"]
if (
composition_reduced.get("O") == 3
and all(composition_reduced[x] == 1 for x in other_elements)
and len(composition_reduced) == 3
perovskite_docs.append(doc)
thanks a lot vai… actually I havent so much idea about MPRester(). Now I get this
