I downloaded the windows EMC (emc_win32_v9.4.4_20210801), and added the eviroment varible:
EMC_ROOT D:\emc_win32_v9.4.4_20210801\scripts;D:\emc_win32_v9.4.4_20210801\bin.
However, when I start EMC by emc_setup.pl bulk, error message occurs ‘emc_setup.pl’ is not the interal or exteral commands.
Another problem
When I executed the conmand “emc_setup.pl bulk” successfully, I got the files bulk.in and build.emc.
While when I executed the conmand “emc_win32 build.emc”, error messages occurs:
Error: core/format.c:359 FormatOpen:
Error opening file “D:/emc_win32_v9.4.4_20210801/scripts,D:/emc_win32_v9.4.4_20210801/bin,/field/opls/2012/opls-ua.prm”.
Program aborted.
Your error occurs, because you set multiple values simultaneously in your EMC_ROOT environment variable, which together do not constitute to a valid path.
The environment variable EMC_ROOT should point to the root directory of EMC. For example, if you would like to install EMC v9.4.4 on a Windows drive D: in directory emc, you change the directory to D:\emc and unpack the distribution there. This unpacks EMC in subdirectory v9.4.4. In this case, you would set EMC_ROOT to
D:\emc\v9.4.4
If you want for EMC to be executed without having to type the full path, you would have to add
D:\emc\v9.4.4\bin
D:\emc\v9.4.4\scripts
to the environment variable PATH. When referring to environment variables, Windows uses %-s, e.g. the PATH variable can be printed by typing
echo %PATH%
at a command prompt.
Environment variables can be changed as follows:
Type ‘advanced system settings’ in the search option box next to the Windows icon and press enter, which opens the ‘System Properties’ window
Click on ‘Environment Variables’, which opens the ‘Environment Variables’ window
The ‘Environment Variables’ window consists of two sections: ‘User variables’ and ‘System variables’. I would suggest adding and changing values under ‘User variables’. Add a new EMC_ROOT environment variable as follows:
Click New at the ‘User variables’ section, which opens the ‘New User Variable’ window
Enter EMC_ROOT in the variable name field
Enter D:\emc\v9.4.4 in the variable value field
Click OK at the bottom of the ‘New User Variable’ window to confirm your entries, which closes the window
Add the EMC scripts and bin directories as follows:
Double click the Path entry under ‘User variables’, which opens the ‘Edit environment variable’ window
Click New
Enter D:\emc\v9.4.4\bin and press enter after typing
Click New again
Enter D:\emc\v9.4.4\scripts and press enter after typing
Click OK at the bottom of the ‘Edit environment variable’ window to confirm the added paths, which closes the window
Finally, click OK at the bottom of the ‘Environment Variables’ window to confirm your choices. Typically, all edits are not stored if the latter is not performed.
I would suggest installing Strawberry Perl (https://strawberryperl.com), if your system does not have a version of Perl installed.
