Dear lammps users,
Now I’m trying to simulate a poiseuille flow by “fix addforce” command. I also use the “fix wall/reflect” command and does not add an actual solid wall at the boundary.
But the results show that the velocity distribution is uniform, not parabolic.
So What’s wrong with my treatment?
Can I simulate a poiseuille flow without adding the actual solid wall? This means the system contains only pure fluid atoms.
I’m looking forward to having your help.
Best wishes
Ruo-Yu Dong
You are asking several questions that have little to do with LAMMPS and more to do with classical mechanics. Nevertheless, I will answer the more obvious.
Dear lammps users,
A simple classical mechanics argument should tell you that you cannot do this. You are forcing particles in a direction orthogonal to a reflecting wall. Momentum of the particles in the forcing direction cannot be changed by a collision with a reflecting wall perpendicular to it(write out some vector equations an this should be obvious).
See above.
In short, no. At least not without some boundary condition to alleviate the problem above, and any conservative potential serving as your wall will give you the same problem as above.
Dear lammps users,
Now I'm trying to simulate a poiseuille flow by "fix addforce" command. I
also use the "fix wall/reflect" command and does not add an actual solid
parabolic.
why should it be parabolic? think about what it is *exactly* that
slows atoms down that are close to the wall.
So What's wrong with my treatment?
that you don't consider the physics of the model.
you can, but it is not a trivial as you currently think it is.
