Dear All,
I am simulating an nano particle combustion system in which radiation heat transfer is really important.
In my system, there is a metal nano particle suspend in oxygen gas and I desire to add radiation heat between particle and gas molecules.
Radiative heat transfer equation is also simple: Qrad=εkBA(T1^4-T2^4) where ε and A are constant number related to properties of material itself. kB is Boltzmann constant.
However, in LAMMPS, there is no relevant commands deal with radiation heat transfer.
Now, I design a method as follow:
First, compute temperatures of the particle and oxygen gas respectively.
Then, according to the equation, compute Qrad through variable and compute commands.
Last, adjust new temperature in both particle and oxygen molecules by using fix temp/rescale command.
A question also rises in such method: how often should I renew temperatures by this method? every step?
Could this method reasonably describe radiation heat transfer? If so, what about the following question?
If not, what I can do to simulate such situation?
Any suggestion will be very appreciated.
Best regard,
Junpeng Liu
