How to solve this energy minimization issue for high entropy alloys in lammps?
I am trying to determine some mechanical properties of Hf-Nb-Ta-Zr high entropy alloy. But I’m not being able to relax it properly & it’s causing absurd values of elastic moduli, double-necking during tensile tests etc. issues. Same codes work for single metals but I don’t know what to do for HEAs. The potential energy values do converge in thermo outputs… I can’t figure out what the exact issue is. The minimization part of the code is:
#minimization
fix rel all box/relax x 0 y 0 z 0 couple none
minimize 1e-6 1e-8 10000 100000
min_style cg
unfix rel
reset_timestep 0
#NVT_thermalization
velocity all create 1.0e-5 123456 mom yes rot yes dist gaussian
fix NVT all nvt temp 1.0e-5 ${STemp} 0.05 tchain 10
run ${EQRUN}
unfix NVT
#Annealing
fix equil all langevin ${STemp} 1e-5 0.05 123456 tally yes zero yes
fix NVE all nve
run ${EQRUN}
unfix equil
unfix NVE
#Pressure Relaxation
fix NPT all npt temp 1.0e-5 1.0e-5 100 x 0.0 0.0 1000 y 0.0 0.0 1000
run ${EQRUN}
unfix NPT
#NVE Equilbrium
fix NVE all nve
run ${EQRUN}
unfix NVE
You may be able to use the protocols in this paper: Full article: Molecular dynamics study on dynamic mechanical behaviour of FeCoCrCuNi high entropy alloy the material has high entropy (as the name says!) and so having a properly mixed initial condition will be crucial, by random generation on a lattice and/or Monte Carlo atom swaps.
What makes you think that the issue is with the minimization protocol and not the system setup or the choice of potentials?
I have run the same code for for Al and Si; both yielded satisfactory results. Those two only required the direct minimization command. For the alloy, just the necessary create_box and create_atoms command were changed and it caused weird results even after nvt & npt. So the problem is either the potential or my relaxation procedure. Since the potential was procured from the reference of a journal paper, I think my code is the issue here
Yes, but it is more likely your code for creating the system is at fault for issues like you describe than the minimization protocol. This is supported by the fact, that you get expected results for single element systems.
Wow so that means the problem lies before minimization. I mistook the initialization as too simple to have a problem there, sorry. Can you please let me know where the issue is? This is the initial geometry creation upto minimization:
#-------variables-----------
variable STemp equal 300.0
variable EQRUN equal 50000
variable srate equal 1.0e10
------------------------ INITIALIZATION ----------------------------
atom_style atomic
variable latparam equal 3.63
variable fHf equal 25
variable fNb equal 25
variable fTa equal 25
variable fZr equal 25
----------------------- ATOM DEFINITION ----------------------------
lattice bcc ${latparam}
region HEA block 0 100 0 20 0 20
create_box 4 HEA
------------------ Create different types of Atoms --------------------
create_atoms 1 region HEA
set type 1 type/fraction 2 ((v_fNb+v_fTa+v_fZr)/100.0) 1738 set type 2 type/fraction 3 ((v_fTa+v_fZr)/(v_fNb+v_fTa+v_fZr)) 1755
set type 3 type/fraction 4 $(v_fZr/(v_fTa+v_fZr)) 6688
------------------------ FORCE FIELDS ------------------------------
pair_style eam/alloy
pair_coeff * * Hf-Nb-Ta-Zr.eam.alloy Hf Nb Ta Zr
neighbor 2.0 bin
neigh_modify delay 10 check yes
------------------------- SETTINGS ---------------------------------
compute csym all centro/atom bcc
compute potatom all pe/atom
EQUILIBRATION
reset_timestep 0
timestep 0.001
#minimization
Please wrap your input script as a code block using triple backticks,
like this,
so we can read it without formatting problems. Thanks :slight_smile:
# ------------------------ INITIALIZATION ----------------------------
atom_style atomic
# ----------------------- ATOM DEFINITION ----------------------------
create_box 4 HEA
# ------------------ Create different types of Atoms --------------------
set type 1 type/fraction 2 ((v_fNb+v_fTa+v_fZr)/100.0) 1738 set type 2 type/fraction 3 ((vfNb+vfTa+vfZr)/100.0)1738settype2type/fraction3((v_fNb+v_fTa+v_fZr)/100.0) 1738 set type 2 type/fraction 3 ((v_fTa+v_fZr)/(v_fNb+v_fTa+v_fZr)) 1755
# ------------------------ FORCE FIELDS ------------------------------
neighbor 2.0 bin
# ------------------------- SETTINGS ---------------------------------
# EQUILIBRATION
reset_timestep 0
timestep 0.001
#minimization
Can you please share the alloy file for HEA?
