hey there, I’m trying to simulate a project which is about nanowire of Ni3Al. I’ve already found cif file of the structure of Ni3Al .however, as i am beginner in this field, i dont know how expand this file in my coding context to achieve nanowire. Can anyone help me?
Thnks.
You need to look for some pre-processing tool that can help converting the file to a usable data file or you need to figure out how to enter a proper crystal structure using the lattice, region, and create_atoms commands to build your system.
You may also want to work your way though some of the available tutorial material and the corresponding introductory sections of the manual to have a better understanding of how to operate LAMMPS before starting with your research project.
You can use gdis to manipulate the CIF file (eg making supercells, deleting and manipulating atoms --either interactively with CTRL+mouse, or via a transformation matrix), and then export the structure to PDB or XYZ formats.
You may need to post-process these structures, e.g. sorting atoms by element or assigning unique names, depending on the force field you are using. I hope it’s enough to get you started.
