Dear lammps-users
There is a problem has been bothering me for a long time.I want to use Muller-Plathe algorithm (RNEMD) to calculate thermal conductivity of water.
I know fix thermal/conductivity command can swap the different atoms now, but I don’t know how to use this command to deal with the molecular like water.From literature, we know that we should swap the molecular center-of-mass velocities,rather than atomic velocities. But I really don’t know how to use lammps to swap the molecular center-of-mass velocities. Below is my in.water,I know it is wrong,because it swaps the atoms of water,rather than center-of-mass velocities ,so the energy of system is not conserved.
Looking forward to your reply!
Jack zhuang
variable den_nvt equal “90018.015410/6.022/vol”
variable kB equal 1.3806504e-23 # [J/K] Boltzmann
variable kCal2J equal 4186.0/6.02214e23
variable T equal 298
variable V equal vol
variable dt equal 0.5
units real
atom_style full
read_data data.water
pair_style lj/charmm/coul/long 8.0 9.0 9.0
pair_coeff * 2 0.0000 0.0000
pair_coeff 1 1 0.15535 3.166
kspace_style pppm 0.0001
bond_style harmonic
angle_style harmonic
bond_coeff 1 554.1348 1.000
angle_coeff 1 45.7696 109.47
timestep ${dt}
min_style cg
min_modify dmax 0.2
minimize 1.0e-12 1.0e-12 5000 5000
------------- equilibration and thermalization ----------------
reset_timestep 0
velocity all create $T 102486 mom yes rot yes dist gaussian
#fix NPT all npt temp $T $T 50.0 iso 1.0 1.0 1000.0
#thermo_style custom step temp etotal vol v_den_nvt
#thermo 10000
#run 200000
#unfix NPT
fix TEMP all temp/berendsen $T $T 50
fix 1 all nve
thermo 10000
run 400000
unfix TEMP
-------------- flux calculation ---------------
compute ke all ke/atom
variable temp atom c_ke/1.5/{kB}*{kCal2J}
#fix 1 all nve
fix 2 all ave/spatial 1 1000 1000 z lower 0.05 v_temp &
file profile.mp units reduced
fix 3 all thermal/conductivity 10 z 20
variable tdiff equal f_2[11][3]-f_2[1][3]
thermo_style custom step temp epair etotal f_3 v_tdiff
thermo 10000
run 1000000
-------------- thermal conductivity calculation ---------------
--------------reset fix thermal/conductivity to zero energy accumulation---------------
fix ave all ave/time 1 1 1000 v_tdiff ave running
variable k equal (f_3/(2*(step0.5-700000)lxly+1.0e-10))${kCal2J}*1.0e25/(v_tdiff/(lz/2))
thermo_style custom step temp epair etotal f_3 v_tdiff f_ave v_k
thermo 10000
run 5000000
