Dear lammps-user
I want to use the lj/cut/coul/long together with the pair style lj/cut/coul/cut. However, after I run this commands, the error happen. Here is my command and my error. Can the two pair style (lj/cut/coul/long and pair style lj/cut/coul/cut.) be used together? Thank you for your help.
pair_style hybrid lj/cut 15.0 lj/cut/coul/long 15.0 15.0 lj/cut/coul/cut 15.0 15.0
pair_coeff 1 1 lj/cut 0.0 0.0
pair_coeff 1 2 lj/cut/coul/cut 0.00778 3.333
pair_coeff 1 3 lj/cut/coul/cut 0.0 0.0
pair_coeff 2 2 lj/cut/coul/long 0.0067 3.166
pair_coeff 2 3 lj/cut/coul/long 0.0 0.0
pair_coeff 3 3 lj/cut/coul/long 0.0 0.0
The error:
PPPM initialization …
ERROR: Coulomb cutoffs of pair hybrid sub-styles do not match (…/pair_hybrid.cpp:935)
Last command: run 1000000
