Hi all,
I am using PhononMaker from Atomate2 to generate phonon workflows. By default, it uses CHGNet as the phonon displacement maker. I wanted to use M3GNet instead, so I overrode it like this:
phonon_flow = PhononMaker(
displacement=0.02,
store_force_constants=True,
bulk_relax_maker=None,
sym_reduce=False,
symprec=1e-5,
prefer_90_degrees=False,
allow_orthorhombic=False,
use_symmetrized_structure="conventional",
phonon_displacement_maker=ForceFieldStaticMaker(force_field_name="M3GNet"),
kpath_scheme="seekpath",
But when I run it, the output still prints:
CHGNet v0.3.0 initialized with 412,525 parameters
So my doubt is: am I really using M3GNet, or is it still running CHGNet in the background?
There’s another field in PhononMaker, static_energy_maker, which uses CHGNet by default. Try:
displacement=0.02,
sym_reduce=False,
symprec=1e-5,
static_energy_maker = ForceFieldStaticMaker(force_field_name="M3GNet"),
or use the convenience method available in newer versions of atomate2 by first pip install --upgrade atomate2 and then using:
phonon_flow = PhononMaker.from_force_field_name(
force_field_name = "M3GNet",
relax_initial_structure = False,
displacement=0.02,
sym_reduce=False,
symprec=1e-5,
Thanks! This seems to work. But relax_initial_structure = False, doesn’t seem to help. It additionally requires bulk_relax_maker to be set to None.
That’s likely a bug, thanks for catching that!
Hey this should be fixed now, can you try pip install atomate2==0.0.22rc1 and rerun your workflow without setting bulk_relax_maker=None?
