Dear LAMMPS developer and users:
The current issue is an extension of this post: How to set the value of per-atom variables via python? - LAMMPS / LAMMPS Development - Materials Science Community Discourse
LAMMPS version: 20240829
System: CentOS 7
Python: 3.10.15
Following Axel Kohlmeyer’s advice, I now use fix external to acquire the dynamic external force. There is no bug in serial mode. But when I used MPI for parallel computing, many bugs emerged. The program to compute the external force must be in serial becuase it needs the properties of all the atoms in the system. All the quantities requested or scattered in the callback function have been defined in the LAMMPS input script (so the simulation can run normally in serial). Below are some simple Python callback functions I have tried.
from mpi4py import MPI
comm = MPI.COMM_WORLD
me = comm.Get_rank()
# F1
def callback(caller, step, nlocal, tag, x, fext):
comm.Barrier()
if me == 0:
foo = caller.numpy.extract_compute('foo',LMP_STYLE_GLOBAL,LMP_TYPE_SCALAR)
I ran mpirun -np 2 python3 test.py in terminal, the simulation could not start. It didn’t output any more after printing the time step:
A second callback function F2:
comm.Barrier()
if me == 0:
n = caller.get_natoms()
b_info = caller.numpy.extract_compute('bInfo', LMP_STYLE_LOCAL, LMP_TYPE_ARRAY)
For F2, mpirun -np 2 or -np 4 actually ran very well (suprisingly), but -np 6 and more processors raised the error:
Exception ignored on calling ctypes callback function: <function lammps.set_fix_external_callback.<locals>.callback_wrapper at 0x7fa204c9a290>
File "lammps/core.py", line 2236, in callback_wrapper
callback(caller, ntimestep, nlocal, tag, x, f)
File "test.py", line 24, in callback
File "lammps/numpy_wrapper.py", line 186, in extract_compute
return self.darray(value, nrows, ncols)
File "lammps/numpy_wrapper.py", line 495, in darray
ptr = cast(raw_ptr[0], POINTER(c_double * nelem * dim))
ValueError: NULL pointer access
F3
comm.Barrier()
if me == 0:
var = np.zeros(10)
caller.scatter_atoms('d_strain', 1, 1, (var.size * c_double)(*var))
For F3, the bug is the same as that of F1, namely there was no more output after printing the time step.
F4 removed if me == 0:
comm.Barrier()
var = np.zeros(10)
The simulation ran well for -np 2 but the results are not as expected. For -np 4 and more, the bug is the same as F1 and F3.
If comm.Barrier was removed, the bug is the same as that of F1 and F3 regardless of -np.
Another question I am pondering is that the arg fext is per-processor, but the external forces I compute are for all the processors…
