I’m trying to calculate a system including Ge2Sb2Te5 and TiN, employing three pair style quip, meam and lj to desdribe the Ge2Sb2Te5, TiN and the interface, respectively. The commond line used is: pair_style hybrid quip meam lj/cut 10.0 and the hole .in file is attached. The error line is: ERROR: Pair coeff for hybrid has invalid style: gp_merged_2bdmbd.xml (…/pair_hybrid.cpp:525), and the out.log has also been attached. Thank you for your reading and hope for response!
gst_TiN.in (2.4 KB)
out.log (1006 Bytes)
The best place to learn how to use the pair_style hybrid is the official documentation.
If you are too lazy to study it, you can hope for someone to debug your input for you. That’s not me today.
Thank you for your reply, the debug may be the next step I can do it myself, but now I’m not sure if the quip can be used in hybrid and hoping for someone can give the help. Thanks again.
You will never find that out unless you use the correct pair_coeff command. Yours is obviously incorrect and the documentation tells you how it is done correctly.
