Hi LAMMPS users,
Hope everything is well!
I am extremely new to the simulation environment and I am trying to learn how to simulate firstly the adsorption of CO2 molecules into a metal-organic framework (MOF) and then study the diffusivity property of these gas molecules within the MOF structure. I’ve been trying to read as many posts on the mailing list, but there is still some confusion. I’d like to thank you in advance for taking the time to answer my questions.
In order to first study the adsorption of gas molecules in the system, I assume the “fix gcmc” command will help me do that. But I have a few questions pertaining to this step:
Q1. How do I specify using my command that I initially want my gas molecules to be outside the MOF structure and then simulate the number of gas molecules that are absorbed into the structure?
Q2. What exactly should my output components be and against what quantities should I be plotting in order to get an adsorption isotherm?
Nextly I want to study the diffusion property of the adsorbed gas molecules through the pores of the MOF structure, for which I assume that “fix nvt” used in combination with the above command will help me do so, am I right in this direction? If yes, I do have some questions concerning the same:
Q3. Should I run these simulations separately or can I write them together in one single input script?
Q4. In case I can write them together, then how do I use the results that I get from “fix gcmc” to initiate my “fix nvt” command?
Q5. What should my output components be and against what quantities should I plot to be able to analyze the diffusivity property?
Q6. Firstly I want to study a simple rigid MOF structure, what commands should I keep in my input script to be able to do so? In case I want to study how the flexibility of MOF will change the results, then which commands should I change in order to be able to achieve that parameter?
It would be really helpful if you could share a sample input script as to how to go about writing these as steps.
Thank you so much in advance once again, for your time and consideration.
With Regards
Alishba
Hi LAMMPS users,
what do you mean by this statement?
that you are new to using LAMMPS or new to performing MD simulations altogether?
if you have experience in doing simulations before, please explain what kind of systems you have experience with and what kind of software you were using.
i have some suspicions, but i would like to be certain before telling you what i would have to tell you.
thanks,
Hi
I mean that I am completely new to MD simulations and also using LAMMPS. I have never done any kind of simulation before.
With Regards
Alishba
If you have no previous experience in MD, you should not be starting in MD by trying to do a simulation with advanced techniques. that is a recipe for disaster unless you have an adviser that has a lot of experience in that area and guide you through the steps. if i was you adviser, i would still first require you to be able to perform and understand how to run and analyze MD simulations of simpler systems and slowly build your experience and confidence in your choice of parameters and settings.
you may have heard the saying “you need to learn how to walk before you can run”. this is a case where this applies.
also, please note that a) a successful MD simulation requires more than just an input file that runs without crashing. there are many more rather subtle issues that can affect the validity of your results that do not result in crashes, but will will render your simulation data bogus, b) it is strongly advisable to learn MD simulations under the guidance of a (personal) tutor. in many cases that would be your adviser or experienced senior colleagues. if neither has the expertise, your adviser should look for a collaborator with that kind of expertise that is willing to tutor you. starting a new direction of research using advanced methods without any local expertise and without procuring proper training and advising would be extremely negligent, and c) you cannot obtain this kind of tutoring and advice from a mailing list.
Hi
Thank you so much for your valuable feedback. I will look into the recommendations and start with a simpler problem.
