I have an fcc bicrystal with grain boundary constructed at the 210. The system size is 2 million atoms with two grains. I have run a primary Knock on radiation simulation with this system. I have been able to visualize the evolution of the defects (interstitials and vacancies over time). Now, I want to be able to visualize the interaction of the defects with the grain boundary. What is the best method to visualize this?
Thank you @kalcher . That worked out. I was able to visualize the interaction of the defects with the grain boundary, as shown in the attached picture. However, one thing I am wondering whether or not its possible is to visualize the Frenkel pairs(interstitials and vacancies) together with the grain boundary over time. After combing common neighbor analysis and select type, I was able to see the grain boundary and the remaing defects but when i tried adding Wigner Seitz, it’s inactive and i am unble to visualize the FPs interaction with the GB. Can you advise me?
NOTE: The different colors are just different structure types. But I want to be able to see which ones are interstitials and which ones are vacancies and how they both interact with the GB
I’m not sure what you mean by the modifier being inactive, but I believe there’s a point that needs clarification: The particles shown here represent the displaced structure, meaning the actual physical particles. These can be interstitials, but not vacancies.
Please take a look at the two working modes of the Wigner-Seitz defect analysis modifier again:
In the Sites output mode, which is likely the one you want to use, the atoms in the viewports are replaced with their ideal site positions. However, in the Atoms output mode, where the particles of the displaced configuration are kept, identifying vacancy sites isn’t possible.
I run into another problem which i hope you can assist me. I have a bicrystal with two grain boundaries in the middle and at the both ends. Periodic boundary condition is applied at all directions. Now, I want to visualize the bulk defects in the system. My understanding is that i will have to select the two GBs and delete them from the system and then apply the Wigner Seitz. I have done this as shown in the image but it appears that Ovito still gives me the same number of defects as in the entire systme including the GBs. Can you help me out on this?
Is the reference configuration you’re using in the Wigner-Seitz analysis loaded from an external file? If so, did you ensure that the grain boundary was removed from the reference configuration as well?
Yes, I did use an external file as the reference configuration initially, but it didn’t seem to give right result. So, I switched to the upstream pipeline and i encountered the same issues. Now I am thinking whether not the selection criteria for the GBs regions was right. In one instance, i did use the Expression selection and i entered the right GB width and in another instance i use the Slice modifier. I would have thought both of these should give me right result but it didn’t.
Could it be that i need to construct a surface mesh? I am just thinking? @kalcher I will appreciate your thought and assistance on this
