I have a script that generates molecule files that can be read into LAMMPS using read_data. My problem is that this file can generate molecules that lie outside of the simulation box. When reading into a periodic boundary system this is not a problem, but trying to read into a fixed boundary box causes an error. What is the best way to reposition the atoms when reading the data file?
Here the relevant part of the LAMMPS script:
\# Initialization
units real
boundary f f f
atom\_style molecular
log log\.$\{simname\}\.txt
read\_data $\{fname\}
This causes an error as the atoms are outside of the box defined in the atom data file.
I found a way around this, basically I change the atom images and box boundary conditions after loading the data file.
\# Initialization
units real
set atom \* image 0 0 0
change\_box all boundary f f f
But I was wondering is a better way?
the data file?
this is a bug in your script. if atoms are outside the box with fixed
boundaries, then either your script is not properly checking where atoms
are placed or your box dimensions are incorrect.
LAMMPS does the only meaningful thing and discards atoms that are outside
the box. after all, *you* request the box dimensions.
# Initialization
units real
boundary f f f
atom_style molecular
log log.\{simname\}\.txt
read\_data {fname}
atom data file.
# Initialization
units real
read\_data {fname}
set atom * image 0 0 0
change_box all boundary f f f
what if part of a molecule is outside the box? with this "hack" different
parts of the same molecule will end up on different ends of the box.
fix your script to produce valid data files and there are no problems.
