I have three layers of atoms which are C, X, and C, respectively. I want to use airebo potential to describe the atomic intra-layer interaction and lj/cut for interlayer C/X and X/C interactions . Can it be achieved by the following code?
pair_style hybrid airebo 3.0 lj/cut 5.0
pair_coeff * * airebo CH.airebo C NULL C
pair_coeff 2 2 lj/cut 0.0000 3.382
pair_coeff 1 3 lj/cut 0.0000296 3.382
In other words, can this statement "pair_coeff 1 3 lj/cut 0.0000296 3.382" override the airebo setting by "pair_coeff * * airebo CH.airebo C NULL C " between atom type 1 and atom type 3? If not, any suggestion ?
Thanks for any help,
John
atom type 3?
no. AIREBO is not a pairwise additive force field, you cannot simply
override one group of pairs. that will result in bogus force
computations in the manybody contributions.
this is a recurring topic on this mailing list. in the future, please
first research the mailing list archives to find if your problem has
been answered before.
you need to define multiple instances of AIREBO in your hybrid pair
style. please see the documentation for pair_style hybrid. it has an
example for "tersoff".
