I've attached a small example which causes LAMMPS to crash. To
reproduce the crash use these commands. (The first command creates a
restart file "system_after_min.rst". The second command reads it and
crashes.)
lmp_binary_name -i in.min
lmp_binary_name -i in.nvt
crash_example_2012-4-29.tar (10 KB)
crashes.)
The problem appears to be near line 314 of pair_hybrid.cpp. It is
trying to dereference a null pointer ("multiple").
that is only the symptom.
the reason is, that the restart facility
has not been updated to be consistent
with the latest changes in ::settings().
the segfault can be easily avoided,
but that doesn't fix the problem. this
will take a little extra effort.
