Dear All users
When I started my run, I forgot adding compute to represent density profile command,
Now, How can I represent density profile? I should to run again?
Dear All users
Unless you dumped the trajectory you will have to run it again. If you dumped the trajectory with enough frequency during the simulation, you can write a little program to post-process the trajectory into density profiles.
-s-
or use the rerun feature in lammps to process the trajectory file.
