I am having a datafile which contains information in lammps charge style , I want to add Periodic image columns , how can I add?
use “replicate” or “show periodic image” in the “add motification”
In general, you can add new particle properties with the Compute property modifier.
If you choose “Periodic Image” from the drop-down list given under “Output property”, OVITO will add periodic image vectors to the dataset and initialize all values with zeros.
You might also want to have a look at the Unwrap trajectories and Wrap at periodic boundaries modifiers.
Thank you
Thank you for your response
