Despite much searching I have been unable to resolve the following problem with a LAMMPS simulation. I am getting
ERROR: Illegal pair_coeff command (src/KSPACE/pair_lj_charmm_coul_long.cpp:646)
Last command: read_data md.data
and cannot figure out what in my data or input file is wrong.
My input file contains
pair_style lj/charmm/coul/long 9.0 7.0
pair_modify mix arithmetic tail yes
bond_style harmonic
angle_style harmonic
dihedral_style fourier
kspace_style pppm 1.0e-5
special_bonds amber
and the relevant parts of my data file are
Pair Coeffs
1 1 0.1094 3.399670
2 2 0.0157 2.471353
3 3 0.0000 0.000000
4 4 0.2104 3.066473
5 5 0.1700 3.000012
Bond Coeffs
1 303.1 1.535
2 314.1 1.426
3 335.9 1.093
4 301.5 1.439
5 369.6 0.974
Angle Coeffs
1 46.36 110.07
2 67.72 109.43
3 67.78 108.42
4 39.18 109.55
5 50.97 109.88
6 50.84 108.82
7 47.09 108.16
8 62.39 112.45
Dihedral Coeffs
1 1 0.155556 3 0.0
2 1 0.166667 3 0.0
3 1 0.383333 3 0.0
4 2 0.160000 3 0.0 0.250 1 0.0
5 2 0.383000 3 0.0 0.100 2 180.0
6 2 0.144000 3 0.0 1.175 2 0.0
7 2 0.144000 3 0.0 1.175 2 0.0
8 2 0.000000 3 0.0 0.250 1 0.0
9 2 0.000000 3 0.0 0.250 1 0.0
The error message makes me think that my data file is formatted incorrectly, but I have run another simulation with an almost identical format (but using the lj/cut/tip4p/long style instead of lj/charmm/coul/long because the other system also contains water) with no problems.
I was suspicious that the Pair Coeffs for atom type 3 being zero could cause a problem, so I also tried setting those to arbitrary nonzero values. The error message seems to be coming from the KSPACE module, so I also tried commenting out the kspace_style command, but get the same result.
Any suggestions for further troubleshooting would be greatly appreciated!
