Illegal pair_style reaxff ERROR
Dear Lammps Users,
I am trying to simulate C1N1 monolayer using reaxff forcefield in Lammps. My Lammps version is :LAMMPS/29Aug2024-foss-2023b-kokkos on the HPC.
I checked if the package REAXFF is included in the installed Lammps using : lmp -h | grep reaxff
rann reaxff reaxff/kk reaxff/omp rebo
accelerate/cos acks2/reax acks2/reaxff acks2/reaxff/kk acks2/reax/kk
qeq/comb/omp qeq/dynamic qeq/fire qeq/point qeq/reaxff
qeq/reax qeq/reaxff/kk qeq/reax/kk qeq/reaxff/omp qeq/reax/omp
qeq/shielded qeq/slater qtb rattle reaxff/bonds
reaxff/bonds/kk reaxff/species reaxff/species/kk recenter
reaxff/atom reaxff/atom/kk reduce reduce/chunk reduce/region
I am consistently getting error :
ERROR: Illegal pair_style command (src/REAXFF/pair_reaxff.cpp:188)
Last command: pair_style reaxff
I installed lammps on my desktop (lammps-stable_29Aug2024_update2) and also manually installed the package REAXFF followed by make serial. Nevertheless i still get the same error on not recognizing the pair_style reaxff. I have attached the lammps input file for your consideration. Any suggestion will be very useful.
Thanks and Best Regards,
Deepak
c1n1_reaxff.in (407 Bytes)
It means that the syntax of your pair_style command does not follow the specifications, regardless of which version of LAMMPS you try it with. The best way forward is to study the corresponding manual entry.
Apart from the obvious syntax error that @hothello was mentioning, you also are using a ReaxFF combustion force field parameterized for studying the RDX explosive. I don’t think that parameter set is suitable for your objective.
Thanks a lot for the reply. I have checked the syntax on manual. The basic input section is
pair_style reaxff checkqeq yes
pair_coeff * * ffield.reax.rdx C N
I have validated it in details but i am not sure what the error is in the statement. In the forcefield file, the sequence is also in order of C and then N so i really cant figure out the error.
Hint: where is the control file? It’s all documented, so please do your work.
Thanks a lot @hothello
Thanks @akohlmey I will try to use different pair style.
