I am working on active matter simulations and I would like to implement the Active Ornstein–Uhlenbeck Particle (AOUP) model in LAMMPS.
For Active Brownian Particles (ABPs), the recent versions of LAMMPS already provide an inbuilt method through the command: fix propel/self .This makes it straightforward to implement self-propulsion with rotational diffusion.
However, I could not find an equivalent inbuilt fix for AOUPs, where the active force follows an Ornstein–Uhlenbeck process.
Is there any existing LAMMPS fix (in standard packages or USER packages) that implements AOUP dynamics directly?
Any guidance or references to existing implementations would be greatly appreciated.
Thank you very much.
Baburao
