I’m trying to perform free energy computations with the Vashishta potential (part of the MANYBODY package) and would therefore like to use fix adapt which requires the implementation of the extract() method.
I have looked at the source code for already implemented cases in i.e pair_lj_cut.cpp, and think i have understood more or less how extract() should work.
However, it seems like pair_vashishta.cpp (and other potentials in MANYBODY) deviates a bit in how the coefficients of the potential are stored. i.e the epsilon coefficients in pair_lj_cut.cpp are contained in a double** with shape [ntypes+1, ntypes+1]. However, in the Vashishta potential the parameters are stored in an array of “Params” structs.
So from what i understand it is not possible to implement the extract method for MANYBODY potentials. Am i correct in this assumption? If not, any tips as to how i can move forward with this would be greatly appreciated!
