Hey all,
I was trying to run a simulation of a Couette flow with two immiscible liquids. After going through some literature it seems that both NVT and NVE ensemble has been used to perform similar experiments. I understand the basic differences between the two but still not very clear how its affecting my simulation physically.
While doing runs with NVT ensemble the system temp. for certain high shear rates remains below the specified temp. also for low shears the system temp. takes longer time to reach the specified temp. as compared to the NVE. In addition on viewing the simulation I can notice certain clear differences between the two. I havent used NVT ensemble a lot before so I am not sure if I am implementing it wrong. If not I am unable to figure the precise reason for these differences in the two ensembles.
Find below a portion of the log file for both.
Any help would be appreciated.
1) NVT implementation:
compute mobile_thermo all temp/partial 0 0 1
fix 1 all nvt temp 1.10 1.10 699483
fix_modify 1 temp mobile_thermo
thermo_modify temp mobile_thermo
Step Temp E_pair E_mol TotEng Press Volume
0 1.0197573 -3.7128231 0 -3.2029524 2.5195931 243312.67
1000 0.59840788 -3.1098235 0 -2.8106242 6.733425 243312.67
2000 0.60908969 -3.1249916 0 -2.8204516 7.1510068 243312.67
3000 0.62306809 -3.1384345 0 -2.8269053 7.4879776 243312.67
4000 0.62844619 -3.1407716 0 -2.8265535 7.6139205 243312.67
5000 0.60948947 -3.113487 0 -2.8087471 7.4118142 243312.67
6000 0.58817264 -3.0785527 0 -2.784471 7.1243117 243312.67
7000 0.56917386 -3.0409778 0 -2.7563954 6.9127935 243312.67
8000 0.5613946 -3.0188694 0 -2.7381765 6.8069541 243312.67
9000 0.55968288 -3.0163616 0 -2.7365246 6.7981283 243312.67
10000 0.56353202 -3.0255496 0 -2.743788 6.8751787 243312.67
11000 0.57583623 -3.0420882 0 -2.7541746 6.9723372 243312.67
12000 0.58495983 -3.0552307 0 -2.7627554 7.0832902 243312.67
13000 0.59267762 -3.0625594 0 -2.7662253 7.1340247 243312.67
14000 0.59345659 -3.0644548 0 -2.7677312 7.1431641 243312.67
15000 0.59554643 -3.0643475 0 -2.766579 7.1621375 243312.67
16000 0.59877612 -3.064916 0 -2.7655327 7.1839501 243312.67
17000 0.60625311 -3.0681451 0 -2.7650234 7.211247 243312.67
2)NVE implementation:
fix 2 all langevin 1.10 1.10 1.0 699483
fix 1 all nve
fix_modify 2 temp mobile_thermo
1000 0.81138357 -2.8204765 0 -2.4147911 7.763242 243312.67
2000 0.8959874 -2.6207826 0 -2.172796 8.1390409 243312.67
3000 0.94151164 -2.5080049 0 -2.0372565 8.1360711 243312.67
4000 0.98742061 -2.4465777 0 -1.9528752 8.2638975 243312.67
5000 1.0033264 -2.420619 0 -1.9189637 8.3682508 243312.67
6000 1.0161084 -2.414238 0 -1.9061917 8.3770801 243312.67
7000 1.0241281 -2.4068499 0 -1.8947939 8.4218208 243312.67
8000 1.0242016 -2.4115978 0 -1.899505 8.3913889 243312.67
9000 1.0242478 -2.4067766 0 -1.8946608 8.3909175 243312.67
10000 1.0199909 -2.40323 0 -1.8932426 8.3977941 243312.67
11000 1.0220728 -2.404828 0 -1.8937996 8.3959923 243312.67
12000 1.0223391 -2.4068242 0 -1.8956627 8.387898 243312.67
13000 1.022556 -2.4057116 0 -1.8944417 8.3861638 243312.67
14000 1.0248803 -2.4027174 0 -1.8902853 8.4053191 243312.67
15000 1.0143922 -2.4071343 0 -1.8999462 8.3758126 243312.67
16000 1.0218506 -2.4044362 0 -1.8935189 8.3910499 243312.67
17000 1.02298 -2.4055939 0 -1.8941119 8.3802911 243312.67
Thank you.
BR/Joseph
