Goal
I’m attempting to import a pdb of a polymer (also built with emc) and then hydrate it. I expect this should be possible given the “import mode=pdb” option and the comments relating to proteins in another post.
Unfortunately the only example with the option, import
, relates to a surface, where the chemistry is explicitly defined. I expect that in a protein example a SMILES definition isn’t expected.
I would prefer to avoid redefining the polymer in a SMILES string and import it so that the polymer has the same conformation. As a next step I will be changing functional groups, so again I would prefer to keep the same conformation.
It would be nice if mol2 files could be imported since they are an export option in Avogadro
Input
chemistry file:
#!/usr/bin/env emc_setup.pl
ITEM OPTIONS
project membrane
replace true
field opls-aa
ntotal 200
mass true
phases poly,water
build_order sequence
percolate true
ITEM END
ITEM GROUPS
W O
ITEM END
ITEM CLUSTERS
poly import, name="polymer", mode=pdb, type=structure, 1 0.88
water W 0.12
ITEM END
There is a psf file in the same directory as the pdb file with the same name.
Output
EMC Setup v4.1.5 (August 1, 2023), (c) 2004-2023 Pieter J. in 't Veld
Info: reading script from "./polymer.esh"
Error: cluster 'poly': does not occur in chemistries
