I am getting error
ERROR: Unrecognized lattice type in MEAM file 2 (…/pair_meam.cpp:712)
Last command: pair_coeff * * library.meam Si C SiC.meam Si C
actually I want to use the MEAM potential parameter " lattice" as ‘b3’ (that is ZnS structure) in SiC.meam file instead of ‘dim’, how I can go for it?
Regards,
Digvijay
I am getting error
ERROR: Unrecognized lattice type in MEAM file 2 (../pair_meam.cpp:712)
actually I want to use the MEAM potential parameter " lattice" as 'b3' (that
is ZnS structure) in SiC.meam file instead of 'dim', how I can go for it?
does it explicitly say in the manual, that a "b3" lattice option is supported?
Thanks axel,
actually it doesnt explicitly say in manual , that a “b3” lattice option is supported but if I want to work on it then how I can go for it?Regards,
digivjay
Thanks axel,
actually it doesnt explicitly say in manual , that a "b3" lattice option is
if it is not listed in the manual, then there is no direct support.
you would have to read, understand, and correspondingly modify the sources.
